Author Topic: help needed,  (Read 1334 times)
Offline antz
help needed,
« on: 16 December 2009, 11:54 »
went out this morning to my car and started her fine , then al off a sudden the temp warning light comes on and i get a nig stop sigh flash up on the dah, have checked my coolent level and that seems fine, any ideas? ive switched the car of strait away to check but not sure what could be,
car is a mk4 gti 20v turbo v reg
hope you got some ideas peeps
Offline Rhyso
Re: help needed,
« Reply #1 on: 16 December 2009, 11:59 »
sounds like a faulty sensor in the coolant tank - common problem
you can either try and clean up the prongs or get a new bottle from VW for no more than £15  :smiley:
Offline antz
Re: help needed,
« Reply #2 on: 16 December 2009, 13:28 »
is that the sensor on the out side of the tank? ive started the car back up and diconected teh sensor but it made no diff
noticed the stop also said check coolant wich i no the level is fine
« Last Edit: 16 December 2009, 13:35 by antz »
Offline richw911
Re: help needed,
« Reply #3 on: 16 December 2009, 18:44 »
As Rhys says  :smiley:
Its the metal prongs inside the expansion tank. Get a new one from VW for around 10 pounds
1JO 121 403B  :smiley:
« Last Edit: 16 December 2009, 18:46 by richw911 »
Offline Rhyso
Re: help needed,
« Reply #4 on: 16 December 2009, 19:50 »
disconnecting the sensor will tell the car there's a problem so its no use unplugging it
Offline Ant1981
  • Feed me, prod me
Re: help needed,
« Reply #5 on: 16 December 2009, 20:52 »
Open the tank, scrape the prongs with a screwdriver and job done. It's simply just a layer of corrosion on the prongs.
'09 Kawasaki Ninja ZX-6R
