Author Topic: 8v to 16v - just the head?  (Read 4366 times)
Offline javalin
« on: 15 December 2009, 21:13 »
All,
So bit bored tonight and was reading the car bits for brake-up, and the 8v to 16v or vr6 sticky and I got to wondering...  If i've a AGG 8v GTI (which I have funnily enough), whats the minimum i'd need?  Could I just whack a head on it?  Surely far too simple.
I expect its too much effort and money to seriously consider - but 115 -> 150 (ish) HP sounds nice.
James
« Last Edit: 15 December 2009, 21:16 by javalin »
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Re: 8v to 16v - just the head?
« Reply #1 on: 15 December 2009, 21:15 »
Loads more differences than just the head.
nick_thomas
« Reply #2 on: 15 December 2009, 21:43 »
Enlighten us the Wayner!
« Reply #3 on: 15 December 2009, 22:00 »
Ok everything I believe the block is different as well as 16V's have oil jets under the pistons.
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 15 December 2009, 23:20 »
head,pistons,block,injection and several bits of wiring are different! (16v uses bosch injection) then the gearbox and its hydraulic clutch
Offline Paul86S2
« Reply #5 on: 15 December 2009, 23:35 »
Putting the 16v head onto an 8v block would be a lot of work.
If all the water and oil ways line up (I suppose some variant of the 16v head will line up) you will be lowering the compression ratio because the 16v combustion chamber is larger. You will then probably need to change the pistons or machine the 8v pistons for cutouts for the valves.
You will then need the whole 16v intake system, throttle body, and air box assembly. Crank sprocket and intermediate shaft, oil pump, and crank trigger wheel etc will need to be changed, as well as sensors and probably sensor positions will need to be changed.
ECU and associated wiring will need to be changed.
Then consider changing to the stronger 02A gearbox and either cable clutch conversion or complete hydraulic clutch.
If you wanted to do a turbo conversion it might be a way to go but the loss of compression ratio plus all the work and effort wouldn't really make it worthwhile. It would be loads easier to transplant the complete abf lump into the car.
Probably loads of stuff I've missed in the above as well.
Paul
Offline VR6-Joe
« Reply #6 on: 15 December 2009, 23:47 »
Just LOL
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline VR6-Joe
« Reply #7 on: 15 December 2009, 23:49 »
Anyone know if I can fit my AEE head onto an ABF block :laugh:
Offline javalin
« Reply #8 on: 16 December 2009, 08:58 »
well just curious - thanks anyway.
Offline chris231280
« Reply #9 on: 21 December 2009, 13:46 »
Bloody hell, I was wondering if this swap / upgrade was worthwhile, but reading this makes me think that just selling my 8v AGG and buying a 16v would be much more cost effective....... And less hasstle.
And I like my 8v again since sorting the cutting out problem lol........ Better the devil you know!
A good bit of insight though.......
