Golf mk4
Golf mk4 TDI
Wazzzer
bagged a tdi 100 BUT problem started on way home help!!!!!!
Topic: bagged a tdi 100 BUT problem started on way home help!!!!!! (Read 2702 times)
vw-8v
Here all the time
13 December 2009, 21:43 »
right it an 51 plate 5 door black no alloys i will take pics b4 i start sorting it out
but on way home i noticed once i was on motorway( test drive was in area cld only get to 60 ish) around 70 plus when you put the foot down as i did to overtake it stutters like mad now i remember readin about a gti 1.8t that had same prob i think it the maf sensor? would my guess b right? or sh*te? how much fix? can i do it myself?
plus once got home checked under bonnet and there oil comming out from what lookes like a oil filter holder(not seen this b4) at front of engine with a torque setting marked on it for when it re titghened?
will get a manual soon as but is it something to b worried about ? (desciption aint the best but too dark for photos)
cheers
Last Edit: 14 December 2009, 21:30 by vw-8v
Steve_PD
Serious forum addict
Cruising around in a Land Cruiser
Re: bagged a tdi 115 at last BUT problem started on way home help!!!!!!
13 December 2009, 21:48 »
that is the oil filter at the front of the engine.
would the car pull above 70? try unplugging the maf and seeing if it improves
vw-8v
Here all the time
13 December 2009, 21:53 »
un plug it? i know what the prob might b but knowing which part it is and whre to find it (i guess next to air filter) but what it look like hmm i do a search for a pic and see if i can find it tommorow. (yeah it pulls but it like it choking and kicking so not a smooth speed increase)
if it does improve is it a grage job? or can it be a simple swap part?
well good news on the filter then as that easy cheap fix( slight weight off shoulder)
Steve_PD
13 December 2009, 22:07 »
oil filter is a 30 second job
look at the airbox and your see a pipe coming off it going to the engine, in the middle of the pipe is the maf sensor, your be able to see the plug on it.
easy to fit a new on and couple clips
Golf mk4
Golf mk4 TDI
Wazzzer
