Author Topic: pinstriping alloys  (Read 1821 times)
Offline dannydubs
  • mk2 gti,mk3 wagon,mk5gti
pinstriping alloys
« on: 13 December 2009, 13:54 »
Hi guys and gals
Im trying to pinstrip a set of alloys but it doesnt seem to be possible to pin strip in a circle
so what im wondering is there a tool i need or does any body have any tips
thanks :wink:
.....the project.........
Offline Neo Badness
  • Feet are for pedals
Re: pinstriping alloys
« Reply #1 on: 14 December 2009, 23:51 »
Easy when you know how...
Set up a rotating work surface that you can lock the wheel to, something like a lazy suzy. Or you can do it with the car jacked up I just find it easier working horizontaly.
Get something like this
http://www.pinstripinguk.com/stripers.htm
Then load with paint, keep your hand still and then rotate the wheel.
Viola one pin striped wheel...
Good luck :wink:
Offline dannydubs
« Reply #2 on: 15 December 2009, 23:37 »
year sounds good but i wana just use vinyl first to make my mind up any tips on how to get a perfect circle
Offline Neo Badness
« Reply #3 on: 16 December 2009, 12:35 »
In vinyl? Used to have plotter cutter that'd cut a perfect circle, I'd go and see you're local T-shirt/ sign printer they should help you out.
