Author Topic: does welding subtract from structural integrity?  (Read 1489 times)
Offline twistedblack69
  • Proud mk2 user and abuser
« on: 10 December 2009, 20:30 »
Got a leak in the car, and the drivers footwell has been sat wet for a week or so, am planning on taking all the carpets out, gettin 'em cleaned etc next week, but am worried that it may have started rotting the floor pans. In this case, if I were to get the floor pans welded, would this leave the chassis particularly weaker than before (before rot/rust)? As far as I'm aware, its too reinforce the chassis, right
Offline danny_p
Re: does welding subtract from structural integrity?
« Reply #1 on: 11 December 2009, 01:20 »
no.
if you weld up the seams on a car the chassi gets a hell of a lot stiffer
all the VW's have gone bar 1.
VW BUSH
« Reply #2 on: 13 December 2009, 19:55 »
Welding will alter the structure of the Steel in the region of the Weld.
This is called the heat affected zone.
Where a large area has been super heated  you will soften the steel and cause it to lose some of its properties.
This is not an issue when welding in floor pans etc but may be an issue on torsional and structural beams etc  :wink:
