Author Topic: Finally found the cause of my boost problems  (Read 18738 times)
Offline dai-cymru
  • 1989 MK2 16V
Re: Finally found the cause of my boost problems
« Reply #30 on: 10 December 2009, 21:26 »
Rhondda ..,where r u ??
pontypridd LLantrsant side  :smiley:
Offline coolio
« Reply #31 on: 10 December 2009, 21:48 »
pontypridd side ... But I'm down Cardiff few times a week
Offline topher
  • Administrator
  • fully functioning
« Reply #32 on: 10 December 2009, 22:35 »
that isn't a boost leak dude, and if it was unmetered air getting in you'd have a fuel trim fault code for lean running
that looks like a meaty air line, what pressure were you putting in and where was it blocked off?
Offline AaronGS
« Reply #33 on: 10 December 2009, 22:52 »
I may be well off here but if there is positive pressure in the Turbo Inlet Pipe how would it suck in air from a normal pressure atmosphere?
Does the pressure of say 15psi not relate to the the manifold side of the compressor wheel? As such would the pipe not be okay in actual driving?
Offline dai-cymru
  • 1989 MK2 16V
« Reply #34 on: 11 December 2009, 04:33 »
10 psi thats a regulator the airline is going into it, and I do have fuel trim codes, blocked off at throtte valve inlet (hose from the i/c)  :smiley:
Offline coolio
« Reply #35 on: 11 December 2009, 11:57 »
mate i pm u with my number if u want the tip ...
Offline Mr_Orange
Build thread clicky
Offline topher
  • Administrator
  • fully functioning
« Reply #37 on: 11 December 2009, 16:04 »
we always have a couple of spares kicking around if you get stuck.. you bringing it to the charity day next month if you've still got it?
Offline vwprime
« Reply #38 on: 11 December 2009, 17:25 »
What about if you went for a clamp like this mate. You can get a lot more clamping on it and a bigger aria to clamp
http://cgi.ebay.co.uk/MIKALOR-BOOST-HOSE-CLAMP-CLIP-RS-TURBO-COSWORTH-74-79MM_W0QQitemZ120492261488QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item1c0de60070
TRANSFORM, & ROLL OUT!
Offline Grand Master Patch
« Reply #39 on: 11 December 2009, 17:42 »
By the look of it you didn't block of the hockey puck either
