Author Topic: Finally found the cause of my boost problems  (Read 18708 times)
Offline dai-cymru
  • 1989 MK2 16V
Re: Finally found the cause of my boost problems
« Reply #10 on: 10 December 2009, 20:50 »
i would of thought it would not matter as it is only sucking in air, there would no real pressure in the pipe.  It would matter on the other side of the turbo as it is pushing air into the inlet manifold.
have you ever put your hand on the inlet side of a turbo?? trust me lots of pressure  :wink:
Offline MaXXeH
  • Golf MK5 GTI
« Reply #11 on: 10 December 2009, 20:53 »
but what is stopping the pressure going out of the air box?
All the turbo is doing is sucking air :huh:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #12 on: 10 December 2009, 20:55 »
the turbo is suckin in air it's a one way thing air is sucked in and forced through the intake pipe (no air is travelling back towards the air box)
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #13 on: 10 December 2009, 20:57 »
what you have to think, that if the TIP isnt connected then the air that is registered by the MAF will not be going into the system and therefore cause mis-fuelling problem. The speed that the turbo spins at will cause alot of intake pressure.
Offline MaXXeH
  • Golf MK5 GTI
« Reply #14 on: 10 December 2009, 20:59 »
so surly no pressure would build up to force the pipe to leak ( Like me having my front door open and trying to pressure the house, it wont work).........  Everytime i have had a pressure test they have done it from the intercooler and manifold.
Offline MaXXeH
  • Golf MK5 GTI
« Reply #15 on: 10 December 2009, 21:00 »
yea but surly sucking would make the pipe stick to the turbo not push it off.
Offline coolio
« Reply #16 on: 10 December 2009, 21:02 »
What tip do u want , standard or aftermarket. ?
Offline dai-cymru
  • 1989 MK2 16V
« Reply #17 on: 10 December 2009, 21:02 »
I know when fitting my TIP i thought that there isnt really alot of lip on the turbo to securely clamp the hoses on, hence why the manufacture used a bolt on item. Makes you think is it worth going down the metal style enlarged TIP from awesome.
how much is the metal one? does that bolt in like the original one?
Offline dai-cymru
  • 1989 MK2 16V
« Reply #18 on: 10 December 2009, 21:03 »
I have the forge aftermarket already, want to put the standard one on
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #19 on: 10 December 2009, 21:04 »
what Dai is trying to say is the pipe is not secure. It's pulling in un-metered air so making his fuelling lean and throwing up the fault codes
