Author Topic: crankshaft lock on AGU?  (Read 1932 times)
jamie16v
« on: 09 December 2009, 16:36 »
whats the best/easiest way to lock the crank on a 1.8t? need to remove the flywheel.
thanks, jamie.
jamie16v
Re: crankshaft lock on AGU?
« Reply #1 on: 09 December 2009, 19:01 »
 :tongue: did it with a bolt and screwdriver against the teeth method
Offline johnaldinho89
« Reply #2 on: 09 December 2009, 19:06 »
use an air gun :P , no need to lock crank that way muha , but if u dont have that option , just get some1 to briefly crank the engine over if use just trying to crack the stretch bolts off im assuming?
jamie16v
« Reply #3 on: 12 December 2009, 20:10 »
crank the engine over while trying to undo the fly to crank bolts?. :huh: and the air gun was a waste of time :tongue:
