Author Topic: De-ionising water filter  (Read 2110 times)
Offline jaydubveedub
« on: 09 December 2009, 11:08 »
Browsing for detailing products I found this:
http://www.theultimatefinish.co.uk/aqua-gleam/0ppm-de-ionising-water-filter-30.aspx
Does anybody have experience of using these? I am guessing that you can rinse your car and you won't get water marks because the water doesn't have any hardness/limescale in it?
Obviously it's best to dry with a waffle weave but I was thinking this could be useful for a 'quick' wash in the winter to get the salt and muck off the car but I wouldn't have to dry it off afterwards.
2003 Passat 1.9 Sport TDI Wagon | Inky Blue | Lots of Wax
Offline kdiz
Re: De-ionising water filter
« Reply #1 on: 09 December 2009, 21:37 »
i think this is pretty obsessive and i don't belive it will not leave water marks on a solid black paint job anyway  :undecided:
Dunno, id rather spend the £70 on other cleaning stuff that will be put to good use. In theory i guess it could work but again that £70 could be put to better use.
Offline dubber36
« Reply #2 on: 10 December 2009, 11:11 »
If you rinse with an open hose as opposed to a pressure washer or a hose attachment, you can "sheet" the water off the car. This will leave much less water sitting on the car inbeads making it much easier to dry.
If you leave lots of beads on the car and not dry it, you will get water marks. Unless its raining that is.
Offline monzablue16v
« Reply #3 on: 10 December 2009, 11:42 »
I just use my RO/DI unit for my saltwiter tank! leaves no residue as it's pure water :)
