Author Topic: Fiscon microphone position  (Read 3002 times)
Offline countrytrucker
« on: 09 December 2009, 10:57 »
I am getting my dealer to fit my phone kit in the car but I was wanting to know where the best microphone position is.
I had read on here that the VW position above the rear view mirror muffles the sound a bit.
Is it best at the top of the A pillar?
I love my GTD
Offline Das Auto
Re: Fiscon microphone position
« Reply #1 on: 09 December 2009, 11:11 »
My Vw dealer fitted my fiscon mic infront of the rev counter its an awesome position my voice is clear as day I asked him where he was going to put it and when he said there I was a bit shocked at first but he said trust me its the best place for a mic and it is
Offline FroGTI
  • Wheel nut
« Reply #2 on: 09 December 2009, 11:24 »
I always fit my Parrot microphones on the steering column between the wheel and the instruments - great sound, as you speak directly into it. Also, the VW steering column has a nice cut-out to site the microphone so that it just sticks out over the top. My Transit van has a factory-fit Bluetooth microphone on the A pillar and sound is not quite so good.
Offline dubber36
« Reply #3 on: 09 December 2009, 12:06 »
I've not thought of putting them on the instrument panel.
I've always stuck mine to the interior light. It's central so that the passenger can use it, and away from the wind noise around the A pillers.
Offline AlanH
« Reply #4 on: 09 December 2009, 13:59 »
The supplier originally fitted the mic behind the passenger-side grille in the lighting console. This didn't work at all. Had it moved to the top of the windscreen - driver's side and a couple of inches to the right of the lighting console. Much better quality as reported by callers.
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
Offline DDg
« Reply #5 on: 09 December 2009, 16:03 »
Tried the following...
1. Top of the dash in the corner (i.e. in front of the tweeter) - crap sound at both ends, bad idea.
2. Top of the A Pillar next to the side window - better but not great - a bit of wind noise.
3. Top of the A pillar, tucked away next to the windscreen (i.e. around the corner from position 2) - best so far and very acceptable.
The Fiscon comes with two little mounting clips of different sizes and also a small sticky backed mounting ball. The smaller of the clips is pretty discreet and good for the pillars, but if you put it between the clocks the sticky backed ball will be perfect.
Offline R32UK
« Reply #6 on: 09 December 2009, 16:27 »
mine is mounted by the rear view mirror. works fine there and is out of sight too. :smiley:
Offline p3asa
« Reply #7 on: 09 December 2009, 16:31 »
Top of the A frame for me. No wind noise at all and if it comes up in the conversation that I am driving, most folk comment on the clarity of the call.
« Reply #8 on: 10 December 2009, 09:45 »
Das Auto and FroGTI, do you guys have any pics of where you have your microphones?
I love my GTD
Offline FroGTI
  • Wheel nut
« Reply #9 on: 10 December 2009, 11:14 »
Here's a quick pic for you. It looks a bit of a mess with the flash, but in reality, when you're in the driver's seat it's 95% invisible. I can just see the mic head poking out over the top of the steering column (if I look hard, which I rarely do when driving) and the Parrot control unit is hidden by the keys.
