Author Topic: New clutch master cylinder, trouble bleeding clutch  (Read 1730 times)
Offline valeboy
« on: 08 December 2009, 20:04 »
hey im stuck iv fitted new clutch master cylinder bout hour n half ago and have been trying since to bleed the clutch and getting no where lol. i havnt got a easy bleed kit tho any ideas people cheers
Offline topher
  • Administrator
  • fully functioning
Re: New clutch master cylinder, trouble bleeding clutch
« Reply #1 on: 08 December 2009, 20:57 »
It's a pain in the arse doing it on your own. You have to pump the pedal slowly and pull it back up by hand a few times then run round and bleed out.. it can take ages.
If you can find a long enough piece of clear tubing, put it over the bleed nipple and dip the other end in the fluid reservoir. Make sure the hose is always in fluid and keep it topped up while your missus/mate/neighbour pumps the pedal until there are no more bubbles in the line.
Don't let the fluid level drop, if the abs pump goes dry you have more problems.
