Author Topic: RCD 510 with SD card - slow  (Read 6247 times)
Offline nickparnell
« on: 08 December 2009, 13:19 »
Got an RCD 510 with Dynaudio (sounds fantastic BTW) - all works fine with MP3 CDs and via USB. However with a 16GB SD Card the RCD 510 takes forever to start up (Please Wait...) - usually done half my journey before it springs into life (seriously takes about two mins). And does this every time you start the card. Annoying. Anyone any experience of this - would a better SD card help ? Any other ideas ?
Offline AlanH
Re: RCD 510 with SD card - slow
« Reply #1 on: 08 December 2009, 16:14 »
An iPod would help!
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
Offline jdjd
« Reply #2 on: 08 December 2009, 16:50 »
Are you storing songs to Individual folders say albums of up to 40 songs, Or are you adding everything into one big folder of 1000+ songs, The latter will cause a very long loadout, Mine turns on more or less then second I hit SD card
Offline nickparnell
« Reply #3 on: 08 December 2009, 19:09 »
Everything in folders arranged by album - so no massive folders at all...
Offline p3asa
« Reply #4 on: 08 December 2009, 19:11 »
Half your journey is 2 minutes?!?  :laugh:
Mine was taking 20 minutes to boot into life. I discovered it was because I had folders with artist names, then inside it had Albums.
I had hundreds of different artists and hence why it took so long.
I took all the Album Folders out and it now boots in around 20 seconds which is a hell of a lot better but not instantaneous which is quite annoying every time you have to start the car up.
Have a look at my previous post http://www.golfgtiforum.co.uk/index.php?topic=135283.0
Offline keelaw
  • It's here!
« Reply #5 on: 08 December 2009, 20:33 »
sounds like a smaller SD card is the only answer...
Mk6 Golf GTI 5dr, DBP, Monza Shadow, Xenons, ACC, RCD510, Park Assist, Camera, Lux pack.... and now bluetooth.... and now DSG!
Offline simonpolly
« Reply #6 on: 08 December 2009, 20:52 »
When you consider up untill 5 years ago computers only came with 6 to 10 gb hard drives,trouble is we now want everything to happen in a instant,16gb of data is quite alot for a car stereo to handle i use a 2gb card with 35+ large albums on it and have no problems.
Golfgti build quality is average at best.
Offline nickparnell
« Reply #7 on: 08 December 2009, 22:32 »
thanks, will try that. Yeah journey often only a few mins! Just need those long pointless drives at the weekend to get some quality time with the car...
Offline flc1962
« Reply #8 on: 08 December 2009, 22:47 »
some one some where else talked about getting a download for the stereo which allows up 2 32gb cards....
Offline DDg
« Reply #9 on: 10 December 2009, 15:07 »
I tried a 4GB SD card against a 16 GB USB stick and found the USB stick was a smidge quicker to load / access, although both were very quick. The USB sticks are a bit cheaper, too.
