Author Topic: How To: DIY W8 Light Mod  (Read 26362 times)
Offline mikemk4gti
« on: 06 December 2009, 16:59 »
 A few people asked for a how to on this so I decided to take a few pics when I did mine for the second time. hopefully the mods can put this into the how to section.
 First you need to get some LED's. You can have any colour you like but I went for red 3mm, you could use 5mm but 3 are perfectly big enough.
 Don't ask me how to remove the interior light as thats how I broke mine, You can remove the lens part by pulling it from the front and it pops off, then you can see 2 phillips screws - remove these. The next bit is trying to get the bl**dy thing out of the roof lining :angry: its held in by 4 tabs in each corner, with a little patience and a small screw driver it will come out ok.
 Right, once the light is out you can choose where to put the LED's, on my second one i put them in the lens and I think it looks 10x better. just drill 2 3mm holes in the lens but make sure that they are clear of the bulbs inside the lamp when fitted.
then drill a hole for the wires to go through
then you can solder the 2 black wires onto the lamp (or if you don't have a soldering Iron you can just connect it to the brown wire that comes into the lamp)
then you need to run a wire from the lamp down to the headlamp switch, remove the drivers door seal at the A pillar then just push the wire through the hole where the lamp fits until it comes out at the top of the A pillar ( can take some fiddling) then run it down the A pillar to the back of the headlight switch. To remove the headlight switch you need to push the switch in and turn to sidelights position then pull. you then need to connect a wire like so:
connect this wire to the red wires from the LED's and test
thats it, all done. put it all back together and admire your handywork :cool:
« Last Edit: 18 January 2011, 19:54 by mikemk4gti »
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline alex160
Re: How To: DIY W8 Light Mod
« Reply #1 on: 06 December 2009, 17:03 »
Very nice mate, will defo be having ago at this next weekend.  :smiley:
2001 Golf GT TDi  150bhp/ 250 ftIb torque  *No smoke, No poke*
Jamex coilovers, 8k HID's, 18" RS6 alloys, Pipercross panel filter. Stage 1 Revo remap.THS FR3 engine mounts, Anniversary headlamps. GTI rear spoiler, Miltek largebore decat/downpipe, Pro-speed cat back exhaust system (V6 4mo style tailpipes) *SOLD*
2002 Golf GT TDi 130. Allard egr removal kit, 18" Audi rs6 alloy wheels. Mk5 rear aero wiper.gen R32 roof spoiler, JOM coilovers, JOM heavy duty adj droplinks
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #2 on: 06 December 2009, 18:25 »
What is the purpose of a W8 light? Is it just to light up the car inside a bit at night?
Offline alex160
« Reply #3 on: 06 December 2009, 18:38 »
Think its just a cool looking item lol, i was under the impression that it was to light up the top of the gear knob.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 06 December 2009, 19:17 »
ambient light while driving. Also interior light icons illuminate as well
Looks good mate, you've given my old light a new lease of life  :cool:
Offline chris_vw_1987
« Reply #5 on: 18 January 2011, 19:44 »
images removed :/
2001 Volkswagen Golf 1.8t - AUM
Offline mikemk4gti
« Reply #6 on: 18 January 2011, 19:47 »
DOH!!!!!
 I'll look into it!
Offline mikemk4gti
« Reply #7 on: 18 January 2011, 19:55 »
Fixed :grin:
Offline mcgee9t2
« Reply #8 on: 28 December 2011, 23:29 »
just wondering, anyone done this with blue leds?
Offline mikemk4gti
« Reply #9 on: 29 December 2011, 09:08 »
You can use any colour you like, I guess blue would look ok too.
