Author Topic: vr6 engine diagram  (Read 8416 times)
Offline maddix0193
vr6 engine diagram
« on: 06 December 2009, 16:54 »
hi peeps, not particularly mechanically minded and cant find any engine diagrams for a mk3 vr6? i have a broken pipe but dont know what it is exactly and need a labelled diagram to get it replaced??
cheers
Offline popleyruss
Re: vr6 engine diagram
« Reply #1 on: 06 December 2009, 17:01 »
can u get a picture of it ???
Just plain dubbin
Offline maddix0193
« Reply #2 on: 06 December 2009, 17:05 »
cud do but havent got a camera at hand. its on the left hand side of the engine block  :sad:
Offline Mikester
  • Civic Type R
« Reply #3 on: 06 December 2009, 17:16 »
Left hand side of the engine at the top of the engine is 2 fuel lines that go down to the front where the injector rail is.
You obvioously have all of your air intake on the left, with breather hoses going to the cam cover.
I only have pics of VR engines in peices.
Can you see it on this image i got of google images
Offline maddix0193
« Reply #4 on: 06 December 2009, 17:27 »
right, this sounds really naive of me but a couple of inches to the left of the 'vr6' writing is that smooth bit of plastic, its the pipe going into the top of that. its a rubber pipe but the seal is plastic and its snapped clean off, i currently have it taped up as the smell coming into the car was rank. sorry for sounding like a spaz but what part is this? :undecided:
Offline popleyruss
« Reply #5 on: 06 December 2009, 17:36 »
i rekon he means the top breather with the plastic valve thing on as they always brake
Just plain dubbin
Offline Mikester
  • Civic Type R
« Reply #6 on: 06 December 2009, 17:37 »
Basically that is the "crank case breather"
It is the most comment part to break on the VR engine.
VW wont sell the pipe without the rest of the intake coming to something like £70+!!
But Ford also used the VR6 engine and will sell just the part you need which comes in at about £20.
The ford part number for the bit you need is: 7 364 573
Alternativly you could fit a universal little cone filter thing from halfords, or a catch tank which can be bought of Ebay.
Offline StevoVR6
« Reply #7 on: 23 May 2011, 11:24 »
Mine is the same as this could this involve a loss of coolant as well?
Offline popleyruss
« Reply #8 on: 23 May 2011, 15:13 »
Nothing to do with coolant I'm afraid
Just plain dubbin
« Reply #9 on: 23 May 2011, 16:08 »
Nope, get your system pressure tested and that will help you find the leak.
