Author Topic: got a fault code reader and got some codes and issues i need help with !!!!!!  (Read 1517 times)
Offline matping
  • MK1 20vT MK5 GTI T
hi   got a  fault code reader  pluged her in to check everything  ! i scanned all ABS  and no faults found ! same with air bag etc
 then i did the engine  and got
00515  - camshaft position sensor (hall effect sensor) - no signal (g4) check CMP if ok replace distributor
00670 - throttle position sensor -g127
16500 -  engine coolant tempreture circuit-range/performance problem
16507 - throttle position sensorA circuit-high voltage input
i know the obvious answer is to replace all this   but im sure the cars running fine   would i know if things like the crank sensor has gone ??
please someone help meee  all the best
Offline Rhyso
Offline dai-cymru
  • 1989 MK2 16V
I take it's a AUM engine looks like your throttle pedal is fooked
Offline matping
its AGU engine
Offline T_J_G
have you cleared all the codes, driven it for a while hen re scanned? they could be old uncleared codes.
Offline matping
ahhhh diddent know you could do that   so ill erase the codes then go out in it and see if they  re appear ?
 i was thinking the cam shaft sensor fault could be   because i had a new belt ??
Offline T_J_G
Yeah clear and re scan in a few days after about 30 miles of driving then re-post your codes again!
