The garage
No washers
Topic: No washers (Read 1974 times)
Tucker
Here all the time
No washers
11 October 2004, 13:15 »
I have no washers
I have checked that I have power with a home made tester bulb and two wires and i have power down to the motor, so I change the motor and still no joy
Any clues?
Tucker
http://i10.photobucket.com/albums/a109/sydney04/mk116vsmallpic.jpg
Sig too large, see forum guidelines - Admin.
topher
Administrator
Serious forum addict
fully functioning
Re: No washers
11 October 2004, 13:26 »
knackered switch
blockage in pipe
bad earth
no water in tank ?
Tucker
Here all the time
Re: No washers
11 October 2004, 14:07 »
Got water in tank
, bulb would not light up if bad earth, or nacked switch
cant even her the motor going
rear does not work either, wipers do
Len
10k hero
Re: No washers
11 October 2004, 14:34 »
A blockage then?
Try taking off the easiest to get at pipe and blowing thru it.
www.sas.org.uk
www.the-ace.org.uk
Tucker
Here all the time
Re: No washers
11 October 2004, 14:39 »
Would that cause the motor to stop?
Will give it a big blow and a poke
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: No washers
13 October 2004, 11:37 »
Get a multimeter, you might not be getting enough voltage to the pump!
Tucker
Here all the time
Re: No washers
Reply #6 on:
13 October 2004, 11:55 »
what should i be getting on it? if its not enough what should i be checking.
I have not checked for any blocks yet but will do tonight.
rubjonny
10k hero
Re: No washers
Reply #7 on:
13 October 2004, 12:00 »
should be 12v I'd imagine!
The garage
No washers
