The garage
Golf Mk2 Heater - No heat!!!...
Topic: Golf Mk2 Heater - No heat!!!... (Read 6227 times)
dubchaser
1989 Mk2 1.8 8v GTI
11 October 2004, 11:29 »
Hi
1991 Mk2 Golf Driver 1595cc.
My heater system no longer works. I just get cold air all the time. No good as it's getting cold out there!
I changed the old heater matrix (hidden below/behind) the dash for a new one. Tis did'nt cure the problem.
Also flushed the system with clean water, including the radiator. Still no joy.
Anyone had the same problem or have any ideas on how to bring my heating back?
I don't want to freeze another winter.
Lee
East Midlands VW Club - Notts, Leics, Lough, Derby etc
*ALSO*
Melton Mowbray and District VW Club:
www.madvw.co.uk
Gambit
Forum addict
Re: Golf Mk2 Heater - No heat!!!...
11 October 2004, 12:27 »
sounds like an air lock in the system
just run the car with the expansion cap off and make sure the heaters are set to max heat.
let it sit idling till either the water boils over or the fan kicks in.
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
13 October 2004, 11:36 »
Might be the bypass valves, to check replace them with straight through piping, make sure the ends are flared so the pipes don't blow off!
Could also be the water pump isn't strong enough or the impeller has dropped off it!
Fielder5757
Guest
15 November 2004, 02:41 »
Ive also just started getting this problem, Problem being i have no idea what any of that means or how the heater works in the first place, i just know i get nothing but cold air
Any help would be Appriatiated
dubslug
15 November 2004, 14:42 »
pop ur bonnet and just below ur water resouir there should be 2 water pipes heading into the car, thats where u should be looking for the valves(big metal or plastic things half way in the piping). i just took em out and put acopper pipe in mine back in feb and havent had a problem since
1992 pearl grey 8v
elnigel
15 November 2004, 18:36 »
the valves were fitted to mk2s after a factory recall, they stop high pressure building up and blowing up the matrix.
you should replace the two valves, they are about a tenner each from german swedish and french parts!
1989 Golf GTI 8v (work in progress!)
1998 Seat Ibiza tdi
dubslug
Reply #6 on:
16 November 2004, 14:57 »
oops, mate never had his on his 4 5 yrs lol
1992 pearl grey 8v
bigkev750
Reply #7 on:
20 November 2004, 17:20 »
same problem here but i am a tight ba?$%&d so i just popped out the sealing ring in the black one and drilled a hole in the alluminium one and hey presto a whole bunch of hot air
The garage
