Author Topic: Another starting problem!  (Read 1387 times)
Offline julie
« on: 01 December 2009, 16:37 »
Hi i have got another starting problem with my mk2 16v golf gti,went to use it yesterday morning and it would not start havent used it all weekend so when i got home from work thought i would try again and it started went to use it this morning would not start again and still wont start now just clicks battery light stays on on dash and oil light flashes? just had a new starter motor put on it about a month ago and has been starting fine until yesterday,could when i had the knackered starter motor on it of killed the battery? battery was bought in feb and is a heavy duty one!
Offline gazpowells
Re: Another starting problem!
« Reply #1 on: 01 December 2009, 21:00 »
had trouble starting mine today i think it was just damp in the electrics  :angry:
so try giving your electrics a spray with WD40 worked a treat for me today
if its making a clicking sound tho,  i would guess you have flattened the battery, give it a good charge overnight and try again in the morning    :smiley:
Offline dub-addict
« Reply #2 on: 06 December 2009, 10:02 »
I had a similar probblem with my mk1 a while ago. it would start when it wanted too, one day it would work fine and the next the starter wouldnt turn the engine over at all.
And what the problem was with mine is that there was a bad contact between the starter motor and the big starter cable , i just put a new spade conneter on and it started fine.
Offline Ben Lessani
« Reply #3 on: 06 December 2009, 11:48 »
Did you change the bell housing bush when you changed the starter?
Offline burnt01
  • We'll get it working
« Reply #4 on: 05 January 2010, 21:37 »
Battery's dont like the cold.  Could just be thats its gone south for the winter.  I thought my battery lost all charge the other night it only just turned over with no start, warmed up a bit the next day and cranked perfectly. See if a jump start helps then your know its the battery.  Other than that the short connector between the motor and solenoid might be a bit loose
Offline roger1234
« Reply #5 on: 05 January 2010, 22:06 »
Check that your earth connections are clean and tight.
