Author Topic: Having problems starting my 18 20v T ????  (Read 2335 times)
Offline craigy
« on: 28 November 2009, 10:36 »
Hi all i was wondering if anyone had any advice for me a few months ago mt golf burnt a valve i rebuilt it and ever since it will not start on 1st turn over then it will usually backfire then will start 80% of the time on the 2nd crank over( wen the fuel pump seems to build pressure) i have changed the fuel pump even.Eventually when it fires up it starts very slow and lazy. I did make a mistake wen building it again by mixing the the petrol pipes (timing belt side) my inlet manifold/intercooler was filled up with petrol. I was told it could be the timung so i striped it and timed it by the haynes manual 100% but i still have the same prob it has been pluged in to a few computers its saying camshaft sensor circuit input low so i have changed the camshaft sensor aswell but still the same the fault code is (PO3011) on a snap on computer as soon as the car fires up it seems to be running 100% it also seems to be harder to start wen cold no one seems to have a clue wot it could be
cheers any help id be gratefull
Offline RnP
  • Audi S4 gone, looking for b5 rs4
Re: Having problems starting my 18 20v T ????
« Reply #1 on: 28 November 2009, 16:18 »
sounds like its fuel pressure related mate, you got a fpr gauge on there??
Offline richw911
« Reply #2 on: 29 November 2009, 12:59 »
Fuel pump relay  :undecided:
Offline craigy
« Reply #3 on: 30 November 2009, 19:46 »
no mate i dnt have a fuel pressure guage also wer could i find the fuel pressure relay???
Offline richw911
« Reply #4 on: 30 November 2009, 22:17 »
Underneath the steering wheel, behind all of the trim  :smiley:
« Last Edit: 30 November 2009, 22:19 by richw911 »
Offline craigy
« Reply #5 on: 01 December 2009, 22:50 »
ok thanks mate very helpfull i cant just understand the tge problem code its givun me about the camshafrt position sensor ???
Offline king nu2 turbo
« Reply #6 on: 10 December 2009, 19:55 »
hi i had the same problem with my golf gti t, turned out to be the timing, on the chain. Take ur rocker cover off and make sure the timing marks line up on the cams, hope it helps
Offline dai-cymru
  • 1989 MK2 16V
« Reply #7 on: 10 December 2009, 20:14 »
the cam sensor will cause running probs, sort that out first  :smiley:
Offline mikemk4gti
« Reply #8 on: 10 December 2009, 21:50 »
sounds like timing tbh, as even with a new sensor it still throws up the same code. and it would explain poor starting.
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
