Author Topic: Idle Problem - Solved.  (Read 4982 times)
Offline LAD
« on: 27 November 2009, 15:38 »
Had to take car to mechanics to sort out idle problem. Revs going up and down from 1000 to 2000. Problem 2 spark plugs had gone. However the car is know is idleing at 600 to 800 but making chugging noise - almost like it wants to stall due to low revs
Possible causes please? coil?, CAT?
Had the car diagonosed apparantly its the diverter valve. They are unreliable due to diaphragm design and are prone to failure. There is a new design available which is a new piston type.
« Last Edit: 29 November 2009, 11:43 by LAD »
Offline FamilyDub
Re: Idle Problem - Solved.
« Reply #1 on: 30 November 2009, 09:51 »
This is almost identical to my issues.
There's an OEM later - and supposedly stronger - revision 'D' diverter valve that can be fitted, which is part number 06H145710D. About £45 from a stealer.
Hope you get it all sorted
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
Offline LAD
Re: Idle Problem - Solved today/PICTURE
« Reply #2 on: 30 November 2009, 11:54 »
The following valve had gone! Cost £30 from stealers.  The car now purr's now!!!!
Part no. 06F 129 101 L :smiley:
« Last Edit: 30 November 2009, 15:52 by LAD »
Offline FamilyDub
« Reply #3 on: 30 November 2009, 16:30 »
Ahhhh, ok.... That looks like a PCV!!
Glad it's sorted! :afro:
EDIT: Check this thread for more info, it does seem to be the PCV:-
http://www.golfgtiforum.co.uk/index.php?topic=126631.0
« Last Edit: 30 November 2009, 16:40 by FamilyDub »
Offline LAD
« Reply #4 on: 30 November 2009, 18:34 »
Yep. PCV aka Snail - Named by stealers.
