General discussion
is the 16valve gearbox different to 8 valve
Topic: is the 16valve gearbox different to 8 valve (Read 1837 times)
billydude
09 October 2004, 12:00 »
as above realy
are the ratios the same etc ?
as we currently have a 1.8 carb box fitted but have two 8 valve gti gearboxs here
so is it worth changeing ?
Last Edit: 09 October 2004, 12:09 by billydude
vwsystems
Guest
Re: is the 16valve gearbox different to 8 valve
09 October 2004, 17:09 »
as far as i know the ratios are different! because its a 16v goes faster top end so will have higher gear ratios
where as the 8v runs out of gears quick!
the revs will be lower if you fit the 16v box to an 8v!
VeeDubGTI16v
Guest
09 October 2004, 18:38 »
2nd and 5th gear are longer in a 8v gearbox, the others are the same i think
billydude
09 October 2004, 19:19 »
Hmmm I wonder what the ratios are as this carb box does 70 in second
and I know the 8 valve don't go that high 55-60 is seconds limit
I don't know what to do wether to run this carb box till it drops or mess about fitting an 8 valve box
Gambit
Forum addict
14 October 2004, 11:08 »
check out all the gearing ratio's here
http://www.scirocco.org/gears/
free
Guest
14 October 2004, 16:20 »
an 8v does 62mph in 2nd, on the limeter,
so ive been told! i have never tryed it my self
(am i a good lyer?)
Gambit
Forum addict
Reply #6 on:
14 October 2004, 16:27 »
simply work it out using the gear ratio link
early 8v's only do 59.8mph
and a 16v will only do 62 on the limiter
Last Edit: 14 October 2004, 16:29 by Gambit
billydude
Reply #7 on:
16 October 2004, 17:20 »
cheers chaps
the decission right now is bugger it the current diff will have had an easyier life than a valver diff
so if it ai't broke I ain't fixing it
General discussion
