Author Topic: tighten throttle cable on mk3 golf 1.4  (Read 2323 times)
Offline AdamBeevers
« on: 25 November 2009, 20:33 »
Hi my idle speed is abit eratic on my golf and i was simply wondering how to tighten the throttle cable. I have taken the airbox of and looked at the carb but there doesnt seem to be any screws or anything to tighten on the wire, can anyone help?
cheers
adam
adamrob69
Re: tighten throttle cable on mk3 golf 1.4
« Reply #1 on: 26 November 2009, 12:54 »
look at the end of the cable where it sits in that metal harnes type device. theres two clips to it, the end clip is where it the end of the cable is held, the clip before it is where you can adjust it. You have to adjust the cable not the throttle body.
Although i dont think this will solve your problem.
Offline VR6-Joe
« Reply #2 on: 26 November 2009, 13:59 »
Dude get it plugged into vagcom!
I had bad idling problems with my 1.6 (same setup as 1.4) when I first got it, and whenever I came to a stop, the engine cut out! .. I tried adjusting the cable, changing plugs, changing dizzy cap, changing air filter, changing ecu relay, etc etc, none of which actually worked so I had doubts about me getting it to run right and wanted to scrap it!
Went round to my mechanic, he plugged it into his computer, it came up with about 3 faults so he checked them on the computer and they were all sensors or switches built into the throttle body. My mate was breaking a 1.6 so I asked for the throttle body, he gave it to me for free because he didn't know if it worked, I fitted it, and everything was perfect again! I was over the moon :smiley:
I don't normally have faith in computerised crap but this actually worked and I couldn't believe it
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
