Author Topic: my revs dip and car stalls almost constantly, wtf???? please help!!!!  (Read 1584 times)
Offline dods84
i have a mk3 golf cabriolet and the car runs fine enough but at junctions etc. as soon as i put clutch in the revs dip and car splutters and stalls. I tried the carb cleaner trick a while ago and did ease the problem slighty but i think it is more too it than this. im pretty lame with cars so any info would be much appreciated. thankyou
« Last Edit: 25 November 2009, 19:25 by dods84 »
Offline Deano2711
  • 1992 VR6
Hi Mate     I have had the same problem recently with my 8v GTi. Take a look at my link "Name that part" in the Mark 3 section. I removed the plug connector from the carbon cannister and have been driving the car for the last few days with it unplugged and it's been great, faster and no cutting out and the revs drop to a normal level when I dip the clutch. There is a pic in my link and this may help or may not. I have been advised in the link to clean the air intake pipes and the throttle body which I will try this weekend. Hope this helps     Cheers     Deano
Offline dods84
sh!t hot deano mate il giv it a try tmora, cheers
Offline Adam
Check the pipe from the rocker cover to the oil filter and airbox isn't blocked or split
Down Hill From Here.
Offline Guy
basics...
is the car serviced regularly?
plugs and HT leads in good condition?
air filter changed recently?
throttle body cleaned?
ps. welcome to the forum
Offline admc6
Get it on vagcom, should show any errors with sensors. Then go from there
Offline dods84
thanks for all the help peeps, il giv it all a go and no i havnt looked after car  aswell as i cud have but has at least 1 service a year. is that bad? and wats the vagcom???? a computer???? my mate has a garage so il c if he has 1. thanks again all
Offline Mikester
  • Civic Type R
http://www.golfgtiforum.co.uk/index.php?topic=136024.0
This is on the same page as your thread........
