Golf mk4
Wazzzer
oil light comes on and engine cut out
Topic: oil light comes on and engine cut out (Read 1352 times)
munnocg
Just got here
25 November 2009, 11:49 »
I have a 1.6 16v year 2000 golf. The problem is, when I am driving the car is running fine but then an oil pressure warning comes on and the revs die. The rev counter shows 0 but you can usually get the car to a safe place at very low revs. The coolant temp gauge on the dash is also a bit temperamental.
Will the two be linked?
what do you think?
Wayne
Sir Postalot
Re: oil light comes on and engine cut out
25 November 2009, 12:24 »
I would get it checked asap and don't use it again until you have it sorted.
T_J_G
Serious forum addict
25 November 2009, 12:43 »
What does the temp gauge do? That could be a dodgy temperature sender for the coolant.
munnocg
Just got here
25 November 2009, 13:39 »
sometimes the temp gauge does not move.
Once it would go up to just about running temp then drop back then go up again. It did this 3 or 4 times then ran at normal.
thanks for the input so far
Rhyso
Global Moderator
Sir Postalot
25 November 2009, 13:51 »
that sounds like a faulty thermostat
Fire Up The Quattro
richw911
10k hero
The Linkmeister and an OEM Freak.
25 November 2009, 18:51 »
Quote from: Wayne on 25 November 2009, 12:24
+1
munnocg
Just got here
Reply #6 on:
07 December 2009, 10:02 »
I fitted a new oil pressure switch and coolant temp switch.
The problem now. The car starts and runs fine till it gets to normal operating temp then it won’t rev above 2000rpm, when you try to rev it, it goes to 2000 then cuts out.
Golf mk4
Wazzzer
