Author Topic: Powder-coating questions  (Read 1790 times)
Offline mjb
  • Mk3 Addiction
« on: 24 November 2009, 22:11 »
I'm going to get a set of my new wheels powder coated....how much should i be looking at per alloy?
There is no major kerbing on the rims just a few scratches....... do i need to do anything before hand.
Instagram @mjbampt
Golf Mk7 Wagon (Work), Mk3 Gti 16v More Door, Mk3 Gti 8v (RIP)
Offline Len
Re: Powder-coating questions
« Reply #1 on: 25 November 2009, 09:20 »
I guess you should ask the company doing the powder coating!
www.sas.org.uk
www.the-ace.org.uk
Offline mjb
  • Mk3 Addiction
« Reply #2 on: 25 November 2009, 20:15 »
I will be doing, just thought i'd put it out there and see what experiences any of you had? Any help would be great.
Instagram @mjbampt
Offline LITTLEGADGI
« Reply #3 on: 25 November 2009, 21:20 »
its come along way more choice of colours b aware its very thick so if u curb them its i nightmare to repair. find a good place 2 get them u will b ok.
Offline clio172
« Reply #4 on: 26 November 2009, 12:13 »
bout 40 a wheel for a quality job, places do if for alot cheaper but you now what happens normally when you go cheap1
1996 Golf Gti Mk3 Colour Concept Green
Offline mjb
  • Mk3 Addiction
« Reply #5 on: 26 November 2009, 16:39 »
I guess it's the old you get what you pay for in terms of quality......like everything, cheers folks i'll keep you updated as to how I get on.
Instagram @mjbampt
Offline reidtastic
« Reply #6 on: 26 November 2009, 22:28 »
Powder coating is a good and bad thing in my opinion. Ive had a few sets of wheels powder coated in the past, here are some little pieces of info that ive found about powder coating through experiance and research.
* Durable finish, so much more so than paint.
*Looks good although its not available in as much colours as paint and ive found that a few powder coaters have dificulty spraying anthracite.
* The powder coated wheels are so much easyer to clean, even just water brings them up like new.
*brake dust doesnt bond to the powder coating like it does with paint
*Some harsh alloy wheel cleaners leave powder coating looking dull.
* I do a few track days and with the heat on the wheels it does dis-colour the powder coating slightly, paint wont do this !
*Also on track days a couple of my friends have lost wheels which were powder coated, mid lap (these wheels were pre torqued before being tracked). After some research it was it was found this was caused by the powder coating process, Due to the stoving off the wheels this alters the structure of the aluminium causing it to react diferantly to heat in the future (EG the heat your wheels see on track days ) which cased it to expand/contract differantly to non heated alloys causing the wheel bolts to loosen. It seems this is Quite well know as when he was towed from the track the guy in the tow truck said " Not someone else with powder coated wheels "
Its also well documented on a few porsche and M3 forums.
I pesonally have not found and loosening of bolts during track days and have always been pretty happy with the wheels, but due to wheels dulling a bit on mine through track use i dont think i would get mine done. I would certainly recommend it to others who just drive on the road ! :cool:
« Last Edit: 26 November 2009, 22:42 by reidtastic »
