Author Topic: exhaust shield  (Read 1936 times)
Offline madgti
exhaust shield
« on: 24 November 2009, 11:59 »
some of the retaining clips on my exhaust shield have broken or rotted away . can i buy them from vw ? ifso does someone have the part number . if can i remove it without it causing any harm to the car
Offline Adam
Re: exhaust shield
« Reply #1 on: 24 November 2009, 12:01 »
Rip them off.
I'm guessing you mean the heatshield on the cat? I removed mine from the mk3 for the same reason.
Down Hill From Here.
Offline admc6
Re: exhaust shield
« Reply #2 on: 24 November 2009, 12:07 »
Mine fell off, and have no probs. Just dont park on any long grass  :wink:
Offline Len
Re: exhaust shield
« Reply #3 on: 24 November 2009, 13:08 »
I suspect its the big heatshileds up against the body at the back? Yes?
If so then yes you can get those circular things, but you could also with the aid of a tap & die set fit washers and nuts!  :wink:
www.sas.org.uk
www.the-ace.org.uk
kells
Re: exhaust shield
« Reply #4 on: 24 November 2009, 13:32 »
7pence each but dont bother they dont fit right, new ones are slightly different, just done mine,and a week later its rattling again :rolleyes:
Offline Len
Re: exhaust shield
« Reply #5 on: 24 November 2009, 13:38 »
Oh and if I am right with the one you're on about then no you cant remove it as it protects the plastic fuel tank!
www.sas.org.uk
www.the-ace.org.uk
Offline VR6-Joe
Re: exhaust shield
« Reply #6 on: 24 November 2009, 17:07 »
Balls does it, I removed all of them from my 1.4 and never had any problems.
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline Mikester
  • Civic Type R
Re: exhaust shield
« Reply #7 on: 24 November 2009, 17:10 »
I believe that len is right in what its "meant to do" but i doubt its actually needed unless you are creating some serious heat....
Offline Len
Re: exhaust shield
« Reply #8 on: 25 November 2009, 09:26 »
Well if a very warm rear box should find itself up against a plastic tank eventually it will melt it! BOOM!
personally I would rather not take the risk.
www.sas.org.uk
www.the-ace.org.uk
Offline Len
Re: exhaust shield
« Reply #9 on: 25 November 2009, 09:27 »
What I really hate is people that ask a question then dont even come back on!  :angry:
www.sas.org.uk
www.the-ace.org.uk
