Author Topic: help needed with picture  (Read 809 times)
Offline theclash
« on: 23 November 2009, 22:03 »
the green plastic plug in this picture has corroded and if i put my finger over it i can feel it sucking in air is this right or should it be blanked off.    its on the opposite end to throttle body (fuel intake i think)
 its a 92 8valve
« Last Edit: 23 November 2009, 22:17 by theclash »
Offline maxp
  • J reg 8v digi gti
Re: help needed with picture
« Reply #1 on: 23 November 2009, 23:11 »
No it should be blocked off.
You can actually buy the caps from vw still.
I would do this as a priority as that air should be diverted into a one-way valve (follow it round, you will see it) which is used to aid braking.
Offline theclash
« Reply #2 on: 23 November 2009, 23:33 »
thanks maxp found it by accident while trying to sort my irratic ideling, i will have to order one.
