Author Topic: possible head gasket failure?  (Read 2019 times)
Offline javalin
« on: 23 November 2009, 21:43 »
Hiya
If I list the symptoms - can somebody check my logic? Also is there a common location where the head gasket fails on the mk3 GTI's? Engine in question is the 8v AGG - about 80k miles.
1) Oil residue in the air box - despite cleaning
2) Oil being blown out of the oil filler cap
3) "Blowing" noise from the airbox when there is any load on the engine. Exhaust has been checked twice and is 100% ok.
4) Gurgling / running fluids sound when the oil cap is removed when the engine is running. By this I don't mean the puff-puff-puff sounds of the compression cycle. Sounds like air is blowing through fluid (oil!?).
5) Possibly a very slight water loss - but this could be a minor radiator leak - so not so worried about this one
6) Lumpy idle
7) Its very hard to drive smoothly when hot and in traffic - i.e. start stop - low RPM. Never sure whether it'll shoot off or stall when I pull off.
7a) Cylinder compression was 165,165,145,145 (PSI)
9) No mayonase. No oil in the water. No overheating.
Have checked the PCV breathers - all clear. My hypothosis is that the gasket is starting to give between 3 & 4 and into the oil channels? Is this a common failure?
Local garage is not convinced - mainly I think due to (9).  Other forum suggested engine wear - but this a new thing - recent problem.
Cheers much!
James
« Last Edit: 23 November 2009, 21:45 by javalin »
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Re: possible head gasket failure?
« Reply #1 on: 23 November 2009, 21:46 »
Oil being blown out of the oil filler cap is a sign of crankcase pressure, if I am correct then your looking at rings or bore wear.
Offline tomsdubs
« Reply #2 on: 24 November 2009, 01:01 »
Does not sound like head gasket, bottom end if you ask me especially with those compression readings.
Offline tomsdubs
« Reply #3 on: 24 November 2009, 01:03 »
Also does it smoke out the exhaust, colour? smell? Use your nose  :smiley:
Offline Guy
« Reply #4 on: 24 November 2009, 03:57 »
that's a useful tip right there kids... to smell something, use your nose!  :grin:
Offline javalin
« Reply #5 on: 24 November 2009, 08:41 »
what am I smelling for?  No smoke other than white out of the exhaust in the mornings that I remember - not driven it for a while, whilst waiting for garage to get round to looking at it.
aka expensive?  You mean rings as in Piston rings? If so can they be changed with the engine in the car?
Thanks all for your help so far,
James
« Reply #6 on: 24 November 2009, 09:06 »
James
Not really, it could be done but quicker to remove and rebuild out of the car.
Offline javalin
« Reply #7 on: 24 November 2009, 09:10 »
ok - Thanks Wayne.
what should be expecting?  I think, from memory, auto-data and bentley seem to be about 10bar - so 160psi or so?
Cheers,
James
« Reply #8 on: 24 November 2009, 09:14 »
ok - Thanks Wayne.
Cheers,
James
Yes but you have 2 at 145 which is low ish.
Offline javalin
« Reply #9 on: 24 November 2009, 09:17 »
ok - so thinking piston rings on cyl 3 & 4?  Is that a common problem on these?  I ask as i've a mk3 1.8 GL as well - that has similar compression readings, lumpy idle etc, but no oil blowing.
edit -> Just spoke to local garage who have been looking at it.  They recon their machine gets 180psi within 10% across 4 cylinders.  Hmmm.  Something is not right, if there is good compression where is the "blowing" noise and oil comming from?
Thanks again,
James
« Last Edit: 24 November 2009, 09:43 by javalin »
