Author Topic: pd or not pd.  (Read 2001 times)
Offline pc16v
pd or not pd.
« on: 07 October 2004, 18:43 »
hi all,i am selling my mk 2 and finaly going for a mk 4 tdi tomorow.my problem is, the 2 i am torn between are 130 bhp with 185 chip , or 110 with leather and bbs 17s. the guy with the 110 dosent know if its a pd engin or not.can anyone help. its a 99 model ,apparently 11/11/99. i will then have to change my name then i suppose. ;D
Offline topher
  • Administrator
  • fully functioning
Re: pd or not pd.
« Reply #1 on: 07 October 2004, 18:58 »
Dont think they made a 110 PD in 1999.  Easiest way to check, how many gears does it have ? PD = 6 speed, tdi = 5 speed.
Chris.
Offline pc16v
Re: pd or not pd.
« Reply #2 on: 07 October 2004, 20:01 »
 ;D cheers chris
Offline frosticles
Re: pd or not pd.
« Reply #3 on: 07 October 2004, 20:31 »
The 110 is NOT a PD engine. Go for the 130 as this is. Well worth it in the long run. You'll only regret not getting the 130 afterwards.
1978 Ford Escort MK2 RS Mexico, GTiTDiPD150. RS2's,Cruise,Metallic Black, Upsolute re-map. Goes and smells like stink.
Offline pc16v
Re: pd or not pd.
« Reply #4 on: 11 October 2004, 22:10 »
got the 130.with chip...nice ;D ;Dnow the wheels an suspension....frosticles , are they rs4 replicas,or the real thing ? i have herd that real ones wont fit .? also there are a lot of the same style out there,and i dont want to get ripped.where did you get yours ? an what  suspension you got.again i here that eibach springs with standard shox work well.i dont want to loosen my fillings anymore just be a bit lower an a bit stiffer :P any info will be nice ...cheers paul
Offline topher
  • Administrator
  • fully functioning
Re: pd or not pd.
« Reply #5 on: 12 October 2004, 14:39 »
Provided your shocks are in good condition, eibach springs are a good choice (even better if your car has the optional vw sports suspension ) ... if you want to spend a bit more then ive been hearing good things about FK Highsport coilovers... very good value.
And yep you're right.. real RS4 wheels wont fit, but the replicas (multi-fit 5x112 / 5x100) go straight on and seem to be good quality, although spoke to a lad on sunday who complained about the weight of them.
Chris.
Offline nrgizerbunny
Re: pd or not pd.
« Reply #6 on: 13 October 2004, 10:19 »
definitely PD!
I heard that bilstein shock/springs were quite good but not a massive improvement over the vw sports suspension
