Author Topic: rear brake difference...?  (Read 746 times)
Offline golfnut8v
« on: 22 November 2009, 17:47 »
is there a difference between the early mk2 84-89,and the later mk2 90-92...rear brakes,discs,bearings,pads,and handbrake cables....
any help on this matter would be super.. :laugh: :laugh:
« Last Edit: 22 November 2009, 18:22 by golfnut8v »
Re: rear brake difference...?
« Reply #1 on: 23 November 2009, 13:07 »
yep, but the change was in 1987, not 1989.
The handbrake lever, cables and callipers are different. Beam, carriers, bearings and discs/pads are the same tho.
The way to tell is to check your handbrake lever trim. If it has a seperate bit screwed to the floor its a late one, if it just has a trim clipped to the lever its early.
Offline golfnut8v
« Reply #2 on: 23 November 2009, 18:38 »
thanks for that.. :grin:
