Author Topic: Where is the immobilisor?!?!  (Read 1692 times)
Offline naturn007
« on: 22 November 2009, 13:35 »
I have been told the immobilisor is behind the glovebox.  I have the glove box out and the shelf.  I want to disconnect the thing, what does it look like?
Many thanks
Offline tweed
Re: Where is the immobilisor?!?!
« Reply #1 on: 22 November 2009, 13:37 »
follow the wires from the plug?
Offline troublestarter
« Reply #2 on: 22 November 2009, 14:56 »
the factory fitted immobiliser module is mounted above the steering column behind the clocks
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline naturn007
« Reply #3 on: 22 November 2009, 19:48 »
Is this easy to access?
Offline laurielaeks
« Reply #4 on: 22 November 2009, 21:41 »
isnt the immobilisers built into the ecu??
the transponder box is behing the clocks, easy to find if you follow the cable coming from the ignition barrell
« Reply #5 on: 22 November 2009, 23:48 »
Yes the factory one is built into the ecu.
Offline naturn007
« Reply #6 on: 25 November 2009, 14:14 »
Thanks all for your responses :smiley:
