Author Topic: gearbox swap??? urgent advice needed!!  (Read 1120 times)
Offline tonysgti
« on: 20 November 2009, 17:26 »
basically the box on my mk3 gti 8v 1995 is on its last legs, i have been offered a box from a 1.6 cl 8v 1997 model. would this be ok, i assume i would still use the gti clutch? i assume i would get a better pull away speed but less top end? any advice/info welcome.
« Last Edit: 20 November 2009, 18:07 by tonysgti »
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
Re: gearbox swap???
« Reply #1 on: 20 November 2009, 17:38 »
As far as i know the ratios are all wrong so bwould be no good.
Seems there are plenty of mk 8v's being broken at the moment, surely it would be better to get a straight swap..?
Offline tonysgti
Re: gearbox swap???
« Reply #2 on: 20 November 2009, 17:44 »
alot of people want silly money for boxes which are untested!! i am trying to find one but have been offered this one cheap.
adamrob69
Re: gearbox swap??? urgent advice needed!!
« Reply #3 on: 20 November 2009, 18:26 »
no, 1.6 box wont do.
expect to pay £200-300 from a breakers for a second hand one, but personaly i wouldnt as its hit an miss if you get a good un or a bad un. I would invest your money wisely in something you know will last.
VW BUSH
« Reply #4 on: 20 November 2009, 21:15 »
Mk2 16v box and clutch ftw (if you can find one which aint fcuked)
Offline boneybradley
  • Back in a Mk3...
« Reply #5 on: 20 November 2009, 23:32 »
any 020 type box (1.8 2.0 8v and some tdi's use this box)
the 1.4 & 1.6 use an 084/085 box (major geekness from me  :nerd:)
VW BUSH
« Reply #6 on: 21 November 2009, 15:30 »
Final drive on Mk2 valver is different im sure.........
Que Rubber Johny to slap me down  :grin:
Offline tonysgti
« Reply #7 on: 21 November 2009, 15:48 »
well update, finally found a box, from a gti, looks as thought it has been refurbed at some point due to being very clean compared to rest of engine. sadly the belt was snapped in car so could not test box but from sitting in car changing gears it fells tighter than mine and it was only £125, putting it in thursday.
