Author Topic: Nasty oil leak!  (Read 883 times)
Offline jezza16v
Nasty oil leak!
« on: 20 November 2009, 09:04 »
Hi all, I have a nasty oil leak from where the oil cooler fits against the upper circular flange (the one with the pressure/temp sender)
Gave it a good clean up, its definately not coming from the senders, it only leaks when the engine is running and is pretty rapid. Is there a seal in there I can replace easily or is it likely to be something more serious? 1990 8v PB by the way......... :sad:
Re: Nasty oil leak!
« Reply #1 on: 20 November 2009, 10:52 »
yep there is a seal between the oil cooler and filter housing, I'd put a new cooler on there at the same time as well, the old one will probably wait a week after you do the job then die  :grin:
15498 - SEAL FOR OIL COOLER - 1.75
15499 - OIL COOLER - 34.60
Offline jezza16v
Re: Nasty oil leak!
« Reply #2 on: 20 November 2009, 11:44 »
Thanks RJ, the oil cooler is a newish VW part fitted by the previous owner 18 months ago according to receipt so should be OK (no receipt for the seal though, I wonder if the old one was used?), I'll just get the seal and have a crack at it this w/e. Going to do thermostat, black temp sender & leaky seal on the water flange on the g'box end as well while the coolant is drained out. Just good that the oil seal went before I did all the other stuff I suppose  :rolleyes:
Offline richard s
Re: Nasty oil leak!
« Reply #3 on: 20 November 2009, 12:50 »
when you do the leaky flange on the head check the head for pitting
Offline jezza16v
Re: Nasty oil leak!
« Reply #4 on: 20 November 2009, 13:09 »
Yes, I had that really bad on my 16v, gave it a real good clean and smoothed it over with Araldite.......worked a treat   :wink:
