Golf mk2
shakey steering
Topic: shakey steering (Read 3398 times)
Rain
Guest
shakey steering
06 October 2004, 18:27 »
think this is pretty common seen fair few posts about wobbles and knocks in the steering but im at a loss.
steering is sold seems to jerk a bit when turning and hitting bumps etc.. also when i hit 55+ it feels like i got arthritis steering wheel shakes but car doesnt its solid on the road as a passenger wouldnt even notice it. ive gone over tracking balancing and ball joints im thinking its probably the a bush in the steering or dampers but this is my first golf and am still getting to know her.
if anyone can help be appreciated.....
dubslug
Re: shakey steering
06 October 2004, 18:55 »
i had the same sort of problems on my last golf it turned out to be that i was missing some drive shaft bolts holding it all together, might be worth a look, also check ur wheel nuts are done up too, read some one found this out to be there problem
1992 pearl grey 8v
Rain
Guest
Re: shakey steering
06 October 2004, 19:01 »
wheels nuts are fine but you might be onto something with the drive shaft as it failed mot cause the boot on the joint was missing didnt bother to check if the shaft and the joints where ok :S do it tomorrow when i got more light.
dubslug
Re: shakey steering
06 October 2004, 19:21 »
good luck fella, i also had a rubber damper on mine split this caused vibrations too but not like u describe
1992 pearl grey 8v
Blue MK2
Guest
Re: shakey steering
06 October 2004, 19:52 »
CV joints,
tracking maybe out?
spigget rings? which im finding hard to find myself.
Rain
Guest
Re: shakey steering
06 October 2004, 22:12 »
tracking is good had it checked today and the wheels balanced.
Gambit
Forum addict
Re: shakey steering
Reply #6 on:
07 October 2004, 10:54 »
spigot rings are usually the cause. are you running aftermarket wheels?
Redcap
Re: shakey steering
Reply #7 on:
07 October 2004, 16:42 »
Try the top strut bearings! This cured mine!
After I had changed CV joints/ wheel bearings and CV boots etc...
Its a GTi
Rain
Guest
Re: shakey steering
Reply #8 on:
08 October 2004, 10:34 »
i got original wheels on the car 14" tear drops.
to be honest we been over so many times and looked at everything its like redcap's done change everything till we get it :S after 15 years im sure it could do with it.
shaggyjh
Re: shakey steering
Reply #9 on:
11 October 2004, 17:08 »
I had really bad shakey steering recently, any braking or speeds over 60mph and it felt like i had square wheels
I took it into the garage and asked if they could check it out, it was caused by warped discs on the front!
New discs and pads and its fine now
Golf mk2
shakey steering
