Author Topic: Mk3 Cutting out! Yes another one.!  (Read 1464 times)
Offline wbbugs
« on: 19 November 2009, 11:54 »
Ok. I have been reading all the threads on this forum regarding this issue. But I have a few differences in my car. For starters its only a 1.4cl Mk3 Golf. ABD engine. It starts lovely. Runs a little rough but only cuts out when it gets warm or 20 miles down the road. Takes 30 minutes before I can start it again.
I am currently in the process of renewing plugs & leads.
Cleaning throttle body.
New fuel pump relay.
New coil.
New dizzy & rotor
Checking all vac hoses & cleaning
Now Alot of people on here have mentioned changing ECU relay. Problem is in my fuse box where this should be positioned there is NO RELAY. Phoned VW and they have not got a relay for this listed for my model. ??? does this Sound right to you guys?
Also mentioned is the crankcase angle sensor. Again I cannot see this and does it have one??
Thanks. Any help appreciated
Offline axewielder
  • 95 dragon 8v
Re: Mk3 Cutting out! Yes another one.!
« Reply #1 on: 19 November 2009, 12:19 »
its a crankshaft position sensor, unsure if yours has one though, you could look on vagcat.com
Offline wbbugs
« Reply #2 on: 22 November 2009, 20:42 »
Done everything that i mentioned and it still cut out. Just changed the fuel filter today and looks like the problem is now sorted. Only time will tell.
Offline admc6
« Reply #3 on: 23 November 2009, 09:42 »
+1
If you do have one, sounds very similar to what happened to me.
Offline axewielder
  • 95 dragon 8v
« Reply #4 on: 23 November 2009, 10:00 »
i was mainly correcting him calling it a crankcase sensor or something but mine went+ was similar problems?
Offline admc6
« Reply #5 on: 23 November 2009, 10:35 »
lol, I should have read it twice  :laugh:
Offline javalin
« Reply #6 on: 24 November 2009, 10:50 »
coolant temperature sensor?  Sounds like it to me - causing it to run rich when hot.  Does the gauge work?  You should get a low resistance across the from the sensor pins when the engine is warm.  The sensor is a 4 pin, gauge on the left pair of vertical pins and ecu temp on the right vertical pairs. (I think from memory)
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
