Author Topic: Removing baked on brake dust  (Read 7145 times)
Offline mf44
« on: 18 November 2009, 20:16 »
Can anyone advise a good way to remove baked on brake dust from the back of alloys. I've taken mine off the car to clean & have tried Autosmart wheel cleaner & P21 powergel but there's still brake dust on them that won't budge. I would like to get them spotless!
Offline Dan J
Re: Removing baked on brake dust
« Reply #1 on: 18 November 2009, 20:25 »
tar and glue remover will help things along if your rims arent extremely manky, if they're not crome you could consider using acid based wheel cleaner which has a bit more bite but use with caution!!!
get as much crap off as you can then get some medium to heavy compound and polish away :smiley:
Offline mf44
« Reply #2 on: 18 November 2009, 22:36 »
I don't know much about tar remover. Is it really aggressive stuff? Safe to use on alloys? I don't really want to use acidic cleaner if I can help it.
« Last Edit: 18 November 2009, 23:53 by mf44 »
Offline Ryan86
« Reply #3 on: 18 November 2009, 22:37 »
Acid based wheel cleaner is spot on but as mentioned use with caution.  It has fast and excellent results tho...
Offline mumbles
« Reply #4 on: 18 November 2009, 23:19 »
t-cut!!!!!! ftw!!! did mine, then polished and waxed them, dust comes off no trouble now and they're oh so shiney!!
Wouldn't be fun if it was easy, but does it have to be this much fun?
Audi A4 Sport
Offline dragonfly
« Reply #5 on: 19 November 2009, 09:43 »
Try Autosmart Tardis.
Offline nogrille
« Reply #6 on: 19 November 2009, 10:25 »
tar remover's vary in strength.  I've heard good things about tardis.  I've used Autoglym tar remover in the passed and it's not worked that well.  I had to clay bar the affected areas, then polish, then seal.  Got there in the end but it took ages
Offline Guy
« Reply #7 on: 19 November 2009, 10:41 »
tardis is great... but i don't find that it works wonders on brake dust, i only usually use it on wheels to remove any remaining tar spots after using smartwheels
Offline waxamomo
« Reply #8 on: 19 November 2009, 17:05 »
Maybe try a strong mix of Meguiar's Wheel Brightener, just make sure you rinse the wheel afterwards.
Offline mf44
« Reply #9 on: 19 November 2009, 17:45 »
What about Meguiars Hot Rims?
