Author Topic: Little Exhaust Query  (Read 2669 times)
Offline Obvious
« on: 18 November 2009, 18:07 »
Evening all,
Have a quick question regarding the center section of the exhaust system. Had my MOT today, she passed but got a couple of advises (Pinhole in the Inner CV boot) and one about the center exhaust. Had MOT done at work (Toyota) and spoke to the tech that did the MOT, now he pointed out the advises to me and the exhaust one bemused me a little. Anyway onto the question..
Around the center section of the exhaust system, there is a \__/ shaped bracket that the center section pipe sits in quite loosely I might add. Now he pointed out that he thought that the center pipe should be tacked or welded to this bracket to stop the exhaust system from moving around. Can anyone confirm that the exhaust should be welded to the bracket as there appears to be no sign of any previous weld/tack.
Offline old_n07
Re: Little Exhaust Query
« Reply #1 on: 18 November 2009, 18:11 »
Yes it should be :afro:
Quite common place to brake, just get it re-welded
Neil
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline Obvious
« Reply #2 on: 18 November 2009, 18:22 »
Cheers Neil
I'll get it tacked tomorrow then.. thought it was a bit of an odd one, because there is quite a bit of movement in the system, but no previous sign of any weld on either the bracket or the center pipe. Cheers for the heads up
Mike
Offline bobreece
« Reply #3 on: 18 November 2009, 18:25 »
sorry to interupt the thread but what wheels are they in you sig pic?
Offline Obvious
« Reply #4 on: 18 November 2009, 18:35 »
You have PM
Offline Steve_PD
« Reply #5 on: 18 November 2009, 18:46 »
you should know about 30 people on here have them :lipsrsealed:
Offline chrisr103
« Reply #6 on: 18 November 2009, 20:03 »
Bit off topic but you said you work at Toyota, Where abouts?
<a href="http://giffgaff.com/orders/affiliate/chrisr45" target="_blank"><img src="http://giffgaff.com/banner/01_80x15.png" width="80" height="15" alt="Get a free giffgaff Sim" /></a>
Offline Obvious
« Reply #7 on: 19 November 2009, 07:25 »
I work for the Denton branch of RRG  :wink:
Offline chrisr103
« Reply #8 on: 19 November 2009, 18:37 »
Ah nice one ill keep a look out when I come down to pick up cars from there that are going to the branch I work at :wink:
Offline Rhyso
« Reply #9 on: 19 November 2009, 19:16 »
mine's be broken at the same point for the last 3 years and it doesn't rattle  :undecided:
Never been mentioned during my MOT either  :huh:
