General discussion
un removeable reg plates
Topic: un removeable reg plates (Read 3378 times)
jontom
24 July 2003, 16:46 »
hi
Does anyone know of an easy way to remove reg plates that that have been stuck on?, mine are so well stuck on i'm affraid the paint will come off too!
jv
Administrator
Serious forum addict
Re:un removeable reg plates
24 July 2003, 19:58 »
Just pull harder! The supersonic sticky tape will surely snap before the paint coming off... had the same problem... went flying across the drive when it did give way!
Suppose you could heat the plate up a bit to try and soften the double sided tape - it works for badges so you never know
jv
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Justins145bhpMK1
25 July 2003, 09:41 »
Had the same prob, I got round it by using a heat stripper thing youd use to get paint off window frames. Its easy as long as you dont want to use the old number plates again as they tend to warp a bit!!!
General discussion
