Author Topic: Anyone using an SD Card for their music?  (Read 12658 times)
Offline p3asa
« on: 17 November 2009, 22:13 »
Bought a 16Gb SDHC class 6 card the other day and put about 5Gb on it.
Put it in the car this morning going to work and for the whole 20 minute journey it said "Please wait accessing"
Coming home it was exactly the same so I decided to leave the ignition on and put it in the drive till eventually it accessed it.
When I pressed "selection" it went up a folder straight away, if I pressed it again to access the whole song list, it went back to the "Please wait accessing" screen for at least 10 minutes until I got p!ssed off with it and turned the bloody thing off.
Anyone using the SD slot? What capacity? And are you having any problems?
Incidentally the couple of songs I did listen to sounded a lot crisper than the songs via the ipod!
Offline flc1962
Re: Anyone using an SD Card for their music?
« Reply #1 on: 17 November 2009, 22:25 »
sorry no usb with 5GB ish plays on switch on
Offline simonpolly
« Reply #2 on: 18 November 2009, 16:31 »
2gb sd works fine no longer than 10 secs wait on switch on.
Golfgti build quality is average at best.
Offline VWKev
  • Please Support Non-Human Rights
« Reply #3 on: 18 November 2009, 17:02 »
Whats the spec of your card ?
GTI mk6, 3dr Manual (Yes Manual! If I wanted a Taxi I'd hail one, not spend £1500 on one), Candy White, Full Leather, Xenons, ACC, 18", RCD510 + Dynaudio, DAB Radio, Winter Pack, Luxury Pack, Fiscon Bluetooth Plus, Golf R LED's.
"Some say he drives a Shopping car, and that his car dent was actually a beauty spot....all we know is he's called Captain Failboat"
Offline p3asa
« Reply #4 on: 18 November 2009, 22:32 »
When I only had a around 20 songs on it was fine but since putting on 5Gb it is useless.
What a waste.
Offline p3asa
« Reply #5 on: 18 November 2009, 22:34 »
Bought a 16Gb SDHC class 6 card the other day and put about 5Gb on it.............
You quoted it  :laugh:
Class 6 is meant to be reasonably fast as well. Reason I picked it.
Offline VWKev
« Reply #6 on: 18 November 2009, 22:49 »
No I saw that, the class rating has to do with data transfer speeds, and nothing else. As I said, whats the spec of your card ? Read speed would be nice.
Offline p3asa
« Reply #7 on: 18 November 2009, 23:09 »
Ah right. I thought they had changed the specs to a "Class" system to make it easier to understand.
Anyway here are the specs:
"Kingston Secure Digital High-Capacity Card (Class 6) 20MB/Sec. 133x Write"
http://www.kingston.com/flash/sdhc.asp?id=8
And its only 8Gb.
Totally useless. 20 minutes to access and then if you try and go up a couple of folders to "all songs" another 20 minutes!!
Offline VWKev
« Reply #8 on: 18 November 2009, 23:20 »
And its only 8Gb.
Had a quick browse, that shouldnt have any probs playing back. Did you format as fat32 ? Also, have you tried just 5 or 6 songs to see if it's the same ?
Offline p3asa
« Reply #9 on: 18 November 2009, 23:26 »
Yeah fat32 and tried about 20 odd songs and it was only a couple of seconds to access.
It seems like it has to load every song again any time the head unit tries to access the SD card.
I'll maybe try another card reader as it was temperamental and may have caused problems when it formatted it.
Then I suppose I could just load 1Gb and test it 2Gb and so on to see what changes happen.
Other than that I haven't a clue how to remedy it.
