Author Topic: Clutch or Turbo Problem  (Read 1169 times)
Offline sardeano
« on: 17 November 2009, 21:28 »
hi, advice/opinion's
Patient Golf Mk4 1.8T running Custom code remap/divertor valve/green filter/smoothed airbox and the latest edition catback Milltek resonant.....
After fitting the exhaust i've having a major problem......when i get a little giddy with my left boot....she accelerates and then there's a sudden burst of power like an automatic really bad.......
is this a clutch problem (slipping)
or
exhaust gases causing a problem with the turbo...
"this as only happened since the exhaust"
help/advice from you guys would be great??????
« Last Edit: 17 November 2009, 21:33 by sardeano »
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Clutch or Turbo Problem
« Reply #1 on: 17 November 2009, 21:36 »
If the rpm gauge is not going up linear and at the same rate as the speedo then it sounds like clutch slip too me.
Fitting the exhaust has allowed for a bit more power from the engine which has just finsihed the cluth off. If you did not fit the exhaust it would have been a few weeks before the clutch started to slip.
Nick
 01455 617233
Offline sardeano
« Reply #2 on: 17 November 2009, 21:47 »
hi, thx...the RPM go's up then the power jumps in.......
if its the clutch do i go for the standard, i've no real plans of anymore upgrades....is the standard clutch capable of handling the mods.....it seems a mine field getting the right part as price is different on every site????
my knowledge is very poor....what would be a average price for a clutch kit??
thx
Offline RTechUK
« Reply #3 on: 17 November 2009, 22:19 »
The OEM clutch will be fine with a stage1 remap, even if you go for the cc stage 2 it will be fine upto around 280lbft.
Our prices are below
Clutch Kits VAG 1.8T / TDI PD
Option 1 : £395 OEM Direct replacement clutch kit. Inc Friction plate, pressure plate, release bearing.
Option 2 : £550 OEM Solid fly wheel conversion. Inc 2.0 16v Solid fly wheel, G60 friction & pressure plates & bearing.
Nick
 01455 617233
Offline TJJONESVDUB
  • Give me lip and il tattoo daihatsu to your head!
« Reply #4 on: 25 November 2009, 17:05 »
or buy a vr6 clutch and g60 flywheel kit almost brand new off ebay for £200
inc bolts
