Author Topic: fuel problem  (Read 1031 times)
Offline scrivo
fuel problem
« on: 16 November 2009, 16:10 »
i have a mk2 16v its a new project and i cant get it to run. The fuel seems to get to the fuel distributor and then not down to the injectors. Has anybody had the same problem? and how was it rectified?
Re: fuel problem
« Reply #1 on: 17 November 2009, 10:12 »
is it an engine conversion or a std 16v?
I had this on my 16v, turned out to be a blocked fuel filter. worth a go!  check for fuel leaks under the car while you're there.
If its a conversion, has it got the correct k-jet fuel pump on there? the digifant one isnt man enough for the job.
Offline scrivo
Re: fuel problem
« Reply #2 on: 17 November 2009, 14:37 »
Its a standard 16v so i will give that a go cheers.
Re: fuel problem
« Reply #3 on: 17 November 2009, 14:56 »
You may find small gauze filters fitted on the banjos, they could be blocked.
