Author Topic: I've joined the GTi world...and i've got a small problem  (Read 2578 times)
Offline Ben Lessani
Re: I've joined the GTi world...and i've got a small problem
« Reply #10 on: 17 November 2009, 09:19 »
Yes one will F**k the engine in cold weather, One won't.
Yep, been there done that - I went on holiday just as Winter was approaching and the car had all water in due to a leaky summer run.
Needed a new matrix, radiator, metal water pipe and core plug :(
50:50 coolant only!
Offline Alec
« Reply #11 on: 17 November 2009, 13:31 »
I'm cutting it rather fine with mine, I had a leak also in the summer so ran only water. Gonna change the temp sensor today or tomorrow and get my heater valve out if I can find some copper pipe to replace it. Hopefully I'l lose enough water to top it up with anti-freeze
Offline Ben Lessani
« Reply #12 on: 17 November 2009, 14:33 »
Other problem to just running water is the corrosion - anti-freeze has inhibitors.
Pop the bottom rad pipe off drain it out (when hot - so the thermostat is open) then top back up with 5l of 50:50.
Offline Horney
« Reply #13 on: 17 November 2009, 14:50 »
I left a MKII GTI over winter with just water in it and never had a problem. Admitadly the car wasn't in use and was parked up on my folks driveway but it was a reasonably cold winter and it snowed several times. It only occured to me it had no antifreeze in it when I went to start it up in the spring, crapped myself, but it was fine.
Nick
Offline Ben Lessani
« Reply #14 on: 17 November 2009, 15:09 »
Some sound advice there Nick :rolleyes:
Offline Horney
« Reply #15 on: 17 November 2009, 15:11 »
Ha ha wasn't advice, just an observation. My folks pond froze over so I guess the water in the golf must have frozen but it didn't do any damage. It's managed 2 seasons in the GTI Champ since then without any failures. It's even running the same box that I drove 60 miles on with no gear box oil in (garage error, not mine I hasten to point out)!
nick
Offline oakgreen_91
« Reply #16 on: 18 November 2009, 13:26 »
Coolant also increases boiling point.
2012 Audi A4 Avant Black Edition TDI 177
2012 Megane RenaultSport 250 Cup
1991 Volkswagen Golf GTI 8v
1990 Renault 5 GT Turbo
Offline Mk2Kezza
« Reply #17 on: 18 November 2009, 20:44 »
« Last Edit: 18 November 2009, 20:46 by Mk2Kezza »
<br />Almost finished.....
Offline danny_p
« Reply #18 on: 19 November 2009, 11:10 »
normaly the freezing itself dosent crack the block  sometimes it tests radiators but not allways.   its when you start a frozen engine you trash it all sort of expensive things can go wrong then
all the VW's have gone bar 1.
