Author Topic: stage 2 and custom map  (Read 2359 times)
Offline coolio
« on: 15 November 2009, 18:21 »
hi rtech !
can u tell me whats the difference between stage 2 and custom map base on the AUM engine with all the toys ....   and how much bhp and torque gain from custom map compare to stage 2 ..?
« Last Edit: 15 November 2009, 18:23 by coolio »
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: stage 2 and custom map
« Reply #1 on: 15 November 2009, 22:50 »
hi rtech !
Custom remap as much as your wanting to go for and as much as your tuning mods will give, really good for and an engine where you have changed an item / items on the engine which changes volumes  it turbo, injectors CR ect.. A full custom remap will take around 2-3 days from start to fininsh.
Stage 2 is also custom, semi custom mapping based on a base spec2 map. which is tweaked to match your cars setup. This takes around 2 to 3 hours.  Spec2 AUM ko3s 3bar fuel set up = 225-230 240-260lbft
Nick
 01455 617233
Offline coolio
« Reply #2 on: 15 November 2009, 23:14 »
 i was hoping u can do the custom map in 1 day cuz i live quite far from u   :undecided:
Offline RTechUK
« Reply #3 on: 17 November 2009, 20:42 »
With your current mods you will only need a Fusion custom remap (semi custom) which can be done in 2 hrs max on the dyno.  If all running right we can give you around 225-235bhp 250-260lbft with super smoothed power delivery to got a really good avg bhp output.
A stock spec2 remap will be around the same peak bhp but lower only around 245-250lbft but maybe a much lower avg bhp
PRICE:
1.8T 20v / 1.9TDI/pd R-Tech Fusion Map = £285 (Spec1/2 custom rolling road remap)
 01455 617233
Offline coolio
« Reply #4 on: 17 November 2009, 21:10 »
If I go for the fusion custom remap , is it possible u can make it slightly more aggressive power delivery to suit my taste ???
Offline RTechUK
« Reply #5 on: 17 November 2009, 21:21 »
Hello,
We can go for aggressive mapping but you will need to alway use higher ron rated fuel, as to get the aggressive feel we will need the give more ignition advance.
Nick
 01455 617233
Offline coolio
« Reply #6 on: 17 November 2009, 21:32 »
That's not a problem ,I always use shell optimax and if I can't get hold of optimax I use super unleaded   ...  I probably have it done in December so hopefully by then u have better offers  :laugh:
