Author Topic: power steering whining  (Read 8146 times)
Offline RnP
  • Audi S4 gone, looking for b5 rs4
« on: 15 November 2009, 15:35 »
Folks im pretty sure its the power steering pump/belt that needs replacing asap, as it whines quite badly when going round bends, but its fine in a straightline, anyone got the part numbers for the above or an idea on how to do it ? thanks
Offline Steve_PD
Re: power steering whining
« Reply #1 on: 15 November 2009, 16:03 »
it will either be the belt or the alternator pulley has seized  :wink:
Offline RnP
« Reply #2 on: 15 November 2009, 16:33 »
cheers steve, I just noticed the power steering fluid was low so took the cap off and spun the steering wheel one way then the other and topped it up, will test it out tomorrow morning hopefully that may of been the problem,
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 15 November 2009, 18:23 »
they whine when the fluid is low so may just need the top up  :smiley:
Offline johnson6672
« Reply #4 on: 15 November 2009, 19:09 »
if it is low and drops again check the pressure switch, its below the opening of the throttle body near the bottom of the engine, mine failed a while back and leaked quite a bit, they are about £20 from the dealers and a 2 min job to change, power steering fluid shouldn't drop.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline Ant1981
  • Feed me, prod me
« Reply #5 on: 15 November 2009, 19:13 »
Exactly.
I couldn't get my head around the earlier post suggesting that it would be the pully siezed. It shouldn't sieze unless the car was stood for years, and then it would whine all the time, regardless of steering position.
But with low fluid, yes, would whine when steering. Would be worse if the fluid was even lower.
'09 Kawasaki Ninja ZX-6R
Offline Rhyso
« Reply #6 on: 15 November 2009, 19:16 »
Steve mentioned the pulley as that's exactly what had happened to his recently
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 15 November 2009, 19:35 »
seriously? Ouch :shocked:
Offline Steve_PD
« Reply #8 on: 15 November 2009, 20:07 »
Exactly.
its a common fault and whines at idle and when turning corners at low speed :tongue:
when my fluid starting dropping down it was the first signs of the steering rack seals going :cry:
Offline richw911
« Reply #9 on: 15 November 2009, 22:34 »
As said if its losing fluid could well be the rack.
