Author Topic: Driver's seat back fabric and foam change  (Read 1902 times)
Offline tony_ack
« on: 14 November 2009, 11:17 »
Lots of guides on here for changing the seat bases (i.e. the easy bit!) but not much for the seat backs. I'm trying to change the foam and fabric over. I've separated the base from the back and managed to unclip the fabric and foam at the bottom of the back, but I'm not sure how to get it past the headrest guides at the top.
Any ideas?
It's a 5 door, so no tilt handle to worry about.
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
Offline dan7
  • 85 T25 camper, 90 Mk2 16v, 90 Caddy
Re: Driver's seat back fabric and foam change
« Reply #1 on: 14 November 2009, 12:02 »
Done this on my mk1 seats. You 'simply' ease the fabric carefully around the guides with a stiff, blunt object. Tricky, but do-able.  :wink:
Offline tony_ack
« Reply #2 on: 14 November 2009, 13:11 »
Managed to get it done!  :cool:
Took some pictures on the way too, so I'll post a guide later.
1995 VW Corrado VR6
Offline Ben Lessani
« Reply #3 on: 14 November 2009, 14:09 »
I gave up when I couldn't get the bloody headrest off!
« Reply #4 on: 16 November 2009, 09:44 »
headrest or the guides?
headrest 'should' just pull out once you remove the lockign clips. sometimes they can be a proper mare though! once the headrest is off the guides can be released using a ring spanner to release all 4 clips at the same time, cant recall off hand what size i used in the end.
Offline tony_ack
« Reply #5 on: 16 November 2009, 13:27 »
I did something similar, but I used the female end of a 3/8" extension
1995 VW Corrado VR6
