Author Topic: Starting Probs with 8v Cabby  (Read 1259 times)
Offline WideBoyGTi
« on: 04 October 2004, 16:39 »
Hiya peeps,
Can Anyone HELP??
Got a 8v cab on a D plate.
The head gasket went, so me and  a mate stripped it down and changed it.
Everything back together now, but it wont start.
Changed all the obvious, (leads,dizzy cap,coil,plugs etc) but still nothing.
The timing is fine, checked that numerious times.
Fuel is getting there fine(i think)
It turns over but it's just not getting the proper sparks.
Wondered if it could be the switch unit, read somewhere that can sometimes cause this problem.
Any one got any ideas.
Sorry it's a long one.
Offline richandhazel
Re: Starting Probs with 8v Cabby
« Reply #1 on: 04 October 2004, 18:10 »
Have you put the earth strap back on the cylinder head? If your head isn't properly earthed that will cause a weak spark. Doubt the head gasket itself provides a very good earth path so your block and gearbox may be fine - hence starter working ok. There should be a seperate strap at the back of the cylinder head/rocker cover :-\
« Last Edit: 04 October 2004, 18:13 by richandhazel »
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
« Reply #2 on: 04 October 2004, 21:02 »
I did this about 3 months ago on my cab, same issue, just ticked over and wouldn't start, had to adjust the timing, moved the distributor a little and it fired up straight away. I then took the car into garage to get timing set correctly, ran perfect after that.
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline WideBoyGTi
« Reply #3 on: 04 October 2004, 22:11 »
I cant say i actually remember putting it back on but i'll shall have a look at the wkend, and let you know.
But cheers for the help.
