Author Topic: help!help! i need help r.tech!  (Read 2721 times)
Offline chrisb gti
« on: 12 November 2009, 22:30 »
 :angry: this feckin cars havin my pants down. all start`d last sunday morn. drove 3mile and park`d up to do sum shopin.didn`t miss a beat. 2hours later got in the car and start`d her up its was a bit lumpy so a quick rev sort`d it i drove 4 fut and new something wasn`t rite.the car woudnt rev and sound`d sh!t. so limp`d it home the power would cum in and then go not the car i no. i rang my m8 who is a machanic and he said nip it round his solas was at home so that was lucky. put it on the solas and code po116 came up (e.t.c.sens.) so it let him reset it and off i went back to the car i no went like a train.got a new e.t.c sens from vag fitt`d at work clear`d the code again and was ok this was monday av just bin out and the feckin things doin it again but worse wont pull then it will ,boggs down at 2600 revs,its doin 19mpg when i alwas get 30 `s ages 2 warm up and is sh!t slow for fecks sake can eny one help? :angry:
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: help!help! i need help r.tech!
« Reply #1 on: 12 November 2009, 23:02 »
Engine coolant temp sensor fault, could be the sensor or loom fault. The ECT fault can cause major running issues if the reading is out of range, the mapping (if you have AUM) have a lot of offset maps related to engine temps.  The snap on tool should have the generic pids which will pick up the real time data from the ECT sensor which will show you what the ecu is seeing, check it from cold and at running temps.
The problem with the performance & being lumpy could be unrelated to p0116, you could have a few other underlaying issues which wont always show up on vagcom.
The first test we always do is disconect the MAF and take the car for a drive to see if the generic sensor mode makes the car run better and smoother... if not then a live run logging session is needed.
What Spec is your car? stock or remapped? tuning mods? Where are you from?
Nick
 01455 617233
Offline chrisb gti
« Reply #2 on: 12 November 2009, 23:14 »
hi nick . am all ways at rtech m8 its the silver 3 door ben remaped not long ago its a agu 007 and a pipercross thats it.
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 13 November 2009, 01:03 »
that narrows it down to about 20 cars fella :grin:
Offline Ben
« Reply #4 on: 13 November 2009, 09:54 »
All he needed to say is lamborghini wheels..lol The we would have known straight away..lol
Pop the car down mate with some choc bickes and I will check the engine out for you m8.
Nick
the dwarf from the north
Offline chrisb gti
« Reply #5 on: 15 November 2009, 09:00 »
 :cool:thanks lads at r.tech .chris had a look. int e.c.t.sens.so spray`d all sens and coilpacks with wd40 and hasn`t play`d up .that was two days ago.
Offline RTechUK
« Reply #6 on: 15 November 2009, 16:44 »
good news m8,  keep us updated you know where we are.
Nick
 01455 617233
