Author Topic: Oil cooler  (Read 2500 times)
Offline maximous
Oil cooler
« on: 04 October 2004, 11:05 »
Hi all would the mk1 oil cooler fit onto my 16v, im assuming so just want to check.
Cheers max
Offline 16v Matt
Re: Oil cooler
« Reply #1 on: 04 October 2004, 11:17 »
Why do you want to put a mk1 oil cooler on a mk2?
Just wondering?
Judderi
Re: Oil cooler
« Reply #2 on: 04 October 2004, 16:51 »
Sorry to hijack but what are the advantages of an oil cooler and do you have to do away with a filter?
Offline maximous
Re: Oil cooler
« Reply #3 on: 04 October 2004, 17:01 »
the 16v ive got runs fine but im planning to take it to the 200bhp mark. One of my friends has done this all ready and required additional cooling. Ive had a look at the oil cooler set up and i cant any reason why it wont change over.
Offline Andy Mc
Re: Oil cooler
« Reply #4 on: 04 October 2004, 18:32 »
My valver is in with my mechainc at the moment having a ported head, 264 deg cams and a flowed inlet fitted, would it be a wise idea to think about getting an oil cooler fitted in the near future??? ;)
If so, which type should I be looking out to get ??? :)
'90 16v
Offline maximous
Re: Oil cooler
« Reply #5 on: 04 October 2004, 18:43 »
I would mate. Its either that or lifting up the hinges at the back of the bonnet, but this doesn't work nearly as good. Its good engine insurance to have one. My friends one come from here i think or is simular.
www.autotech.com/catalog/oilsys.htm
Offline richandhazel
Re: Oil cooler
« Reply #6 on: 04 October 2004, 18:44 »
Am I right in thinking that you are planning to keep the water cooled oil cooler AND add the air cooled oil cooler? Don't see why that wouldn't work.......
Offline maximous
Re: Oil cooler
« Reply #7 on: 04 October 2004, 18:49 »
Yup that's right, the only thing im thinking about is, will it be an easy fit to the engine.
Re: Oil cooler
« Reply #8 on: 04 October 2004, 18:53 »
I would have thought so, the pipes go in the same direction, its the filter head that will cause the problem, not sure that you'll be able to combine the two. I have a mk1 with the air cooled and a mk1 with the water cooled. Could take some pics tomorrow for you if you think it'll help.........Weather permitting :-\
Offline maximous
Re: Oil cooler
« Reply #9 on: 04 October 2004, 19:09 »
That would be realy helpfull thanks alot. Externally the blocks are very simular, i wonder if the mk1 filter holder would change over as well?
