Author Topic: white smoke and more white smoke  (Read 843 times)
Offline theclash
« on: 09 November 2009, 20:25 »
question...would changing the blue temp sensor alter the fuel /co2 setting.
since changing it she throws loads of white smoke out dont think its the head gasket cant check till thursday but only been doing it since i changed sensor.
with it reving on its own aswell its just a plume of white smoke.....one for rubjonny i think
« Last Edit: 09 November 2009, 20:27 by theclash »
Re: white smoke and more white smoke
« Reply #1 on: 10 November 2009, 08:21 »
if the old one was duff, yes it would! the temp sensor tells the engien how warm the engine is, and ecu adjusts fueling to suit.  also if someone didnt do the CO setup correctly the base CO level could be out, which will throw everything out of spec.
when do you get the smoke, idle or on throttle?
Offline theclash
« Reply #2 on: 10 November 2009, 19:39 »
thanks jonny...i get a lot of smoke at idle and not as much when driving.
the old sensor was deffinatley broke and the co2 was last reset at a garage in march for mot emissions. do you think the mixture/co2 will be thrown out and could this also be contributing to my erratic idle aswell.
« Reply #3 on: 11 November 2009, 08:26 »
it may be if they didn't know how to do it properly, not many garages do!
