Author Topic: brake upgrade q's  (Read 1224 times)
Offline squires
brake upgrade q's
« on: 08 November 2009, 20:49 »
i have aquirred a set of 256 brakes for my 8v, im going to change the wheel bearings and pads and discs, but they were off a 4 stud passat, do i use 16v parts when ordering? i havent got the passat details as i had to take the hubs off in my hour lunch break so was in a rush :laugh: the calipers are lucas if it makes a difference?
many thanks lee :smiley:
Offline antogoof
  • bbm mk2 g60
Re: brake upgrade q's
« Reply #1 on: 08 November 2009, 21:41 »
you need the 256mm carriers and hubs as well, the 8v ones are totally different. :smiley:
mk2 bright blue met bits wanted in north west.
Offline Ben Lessani
« Reply #2 on: 09 November 2009, 15:38 »
I'm pretty sure the hub is the same :cool: but the wheel bearing carrier is different ;)
Offline squires
« Reply #3 on: 09 November 2009, 18:37 »
i have got the lot, hub,carrier and caliper and carrier, its just the wheel bearings are shot as are pads/discs, but the problem is when i order new parts  do i ask for late mk2 golf 16v bearings/disc/pads or passat, im pretty sure the wheel bearings are the same but not sure on the pads discs??
cheers :smiley:
jamrock
« Reply #4 on: 09 November 2009, 19:08 »
ive just done the 256 upgrade on mine. its not on the road yet but i have been told it is a very good upgrade as many will tell. you may want to upgrade the master cylinder to the larger one and maybe invest in some braided lines.
« Reply #5 on: 10 November 2009, 08:20 »
MK2 16v or Passat, either is fine as they're the same bearing ;)
Offline squires
« Reply #6 on: 10 November 2009, 19:39 »
cheers :smiley: going to have a busy weekend as im changing the brakes and suspension, wishbones arb etc :laugh: although its been freezing this week need to invest in some garage heaters :wink:
Offline Diamond Hell
  • Opinions я Us
« Reply #7 on: 11 November 2009, 08:56 »
Never mind the garage heaters, sounds like you'd do well to invest in some Plusgas before starting work  :grin:
